Symptoms:
- Current session counter of Virtual-Server or pool is greater than the real number.
For example, if you see the current number of sessions for VIP 10.40.14.34:8443 is 716 but if you actually count the session number using the session-table it is 102, which is far less than the stats output.
edge01> get load-balancer <UUID> virtual-server <UUID> stats
Virtual Server
UUID : <UUID>
Display-Name : lb-pks-<UUID>-virtual-server
VIP : TCP 10.40.14.34:8443
Type : L4
Sessions :
(Cur, Max, Total, Rate) : (716, 749, 140784, 0)
Bytes :
(In, Out) : (7863722100, 3133046605)
Packets :
(In, Out) : (22142738, 10807216)
edge01> get load-balancer <UUID> session-tables | count 10.40.14.34
Number of lines that match pattern '10.40.14.34': 102
