JDBC Connection Reset on 64 bit System Linux System while trying to upgrade/install CA PPM or Jaspersoft fails with below error
Article ID: 32442
CLARITY PPM FOR ITG CLARITY PPM FEDERAL Clarity PPM SaaS Clarity PPM On Premise
Problem:
CA PPM Install/Upgrade Error
 (ExecTask) java.sql.SQLNonTransientConnectionException: [CA Clarity][Oracle JDBC Driver]Connection reset
Jaspersoft Install/Upgrade Error
 JaspersoftInstall/buildomatic/bin/app-server.xml:60: java.sql.SQLRecoverableException: IO Error: Connection reset
Resolution:
1.   Modify the security file of JAVA,
o    Access the java folder on application server , example on Linux  /usr/java/jdk1.7.0_25/jre/lib/security
o    Take backup of file  java.security
o    Open the file java.security to edit and replace the tag securerandom.source=file:/dev/urandom with securerandom.source=file:/dev/./urandom
2.    Save the file and rerun the install/upgrade
Release:
Component: PPMENV
