top -H -p <Datapathd PID>"top - 12:02:23 up 18 days, 22:55, 1 user, load average: 3.09, 3.52, 3.05
Threads: 34 total, 3 running, 31 sleeping, 0 stopped, 0 zombie
%Cpu(s): 14.3 us, 7.5 sy, 0.0 ni, 78.2 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem : 7962892 total, 107536 free, 3884320 used, 3971036 buff/cache
KiB Swap: 0 total, 0 free, 0 used. 3961740 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2936 root 20 0 32.724g 51932 20116 R 91.2 0.7 4:45.58 qos14
2807 root 20 0 32.724g 51932 20116 S 5.8 0.7 3132:44 dp-fp:0
2905 root 20 0 32.724g 51932 20116 S 5.8 0.7 3251:53 dp-fp:1
2916 root 20 0 32.724g 51932 20116 R 3.9 0.7 166:07.93 dp-bfd-mon4
<182>1 2020-10-27T11:46:28.318950+00:00 edge02.example.com NSX 2814 FABRIC [nsx@6876 comp="nsx-edge" subcomp="datapathd.dpc_pb(dp-ipc15)" level="INFO"] QoS enabled on lrouter a21f20eb-####-####-####-5dfd7b0d8f35, dir: 1, committed_bw: 1, burst_size: 1
<182>1 2020-10-27T11:49:48.024808+00:00 edge02.example.com NSX 2814 FABRIC [nsx@6876 comp="nsx-edge" subcomp="datapathd.dpc_pb(dp-ipc15)" level="INFO"] QoS enabled on lrouter 54f67152-####-####-####-5e9773b58c3a, dir: 1, committed_bw: 1, burst_size: 1
<182>1 2020-10-27T11:56:22.440196+00:00 edge01.example.com NSX 2807 FABRIC [nsx@6876 comp="nsx-edge" subcomp="datapathd.dpc_pb(dp-ipc12)" level="INFO"] QoS disabled on lrouter a21f20eb-####-####-####-5dfd7b0d8f35, dir: 1
<182>1 2020-10-27T11:56:45.423255+00:00 edge01.exampe.com NSX 2807 FABRIC [nsx@6876 comp="nsx-edge" subcomp="datapathd.dpc_pb(dp-ipc12)" level="INFO"] QoS disabled on lrouter 54f67152-####-####-####-5e9773b58c3a, dir: 1
This issue is resolved in VMware NSX-T 3.1.2.0 and 3.2.0, available at Broadcom downloads.
If you are having difficulty finding and downloading software, please review the Download Broadcom products and software KB.
restart service dataplane".
