search
cancel
Search
"Host connection and power state" and "Host connection failure" alarms trigger at static intervals
Article ID: 324317
VMware vCenter Server
Show More
Show Less
Symptoms:
These alarms trigger at static intervals:
Note
: Hosts do not disconnect from vCenter Server when an alarm triggers.
VMware vCenter Server 4.1.x
VMware vCenter Server 4.0.x
VMware vCenter Server 5.0.x
To work around this issue, ensure that all times are synchronized between all hosts and vCenter Server.
For information on synchronizing the time with Microsoft Domain Controller, see
Synchronizing ESX/ESXi time with a Microsoft Domain Controller (1035833)
Configuring Network Time Protocol (NTP) on ESX/ESXi hosts using the vSphere Client
Feedback
thumb_up
Yes
thumb_down
No
