What is the difference between using DELETE as opposed to REMOVE in Smarts ASL?
Article ID: 322965
VMware
VMware Smart Assurance - SMARTS
What is the difference between using DELETE as opposed to REMOVE in ASL?
DELETE functionality removes only the object in question whereas the REMOVE functionality deletes the object and all of its relationships.
Feedback
thumb_up
Yes
thumb_down
No
