Symptoms:
- You are doing a VCF upgrade and the VMware edge upgrade fails.
- In the NSX-T manager log /var/log/upgrade/upgrade-coordinator.log we see the following message:
Edge group upgrade status is FAILED: [Edge 4.1.1.0.0.22224312/Edge/nub/VMware-NSX-edge-4.1.1.0.0.22224325.nub post power on task failed on edge TransportNode xxxxxxxx-d120-47e5-bc7c-xxxxxxxxxx: clientType EDGE, target edge fabric node id xxxxxxxx-d120-47e5-bc7c-xxxxxxxxxx, return status Issuing post_power_on failed to complete in time .].
- On the VCenter server edge, the edge node virtual machine's interfaces are found in a disconnected state.
- Edge node upgrade fails in post-upgrade power on task.
Note: The preceding log excerpts are only examples. Date, time, environmental variables and versions may vary depending on your environment.
