The alarm threshold is set at 80%, so with the Edge node size and allowed load balancer size as per below table, the limit would always be breached at 100% and trigger the alarm:
| Edge node size | Credits Available | Load balancer size | Credits required per LB size |
| Small | 1 | Small | |
| Medium | 10 | Medium | 10 |
| Large | 40 | Large | 40 |
| XLarge | 50 | XLarge |
The Edge nodes can only have a specific size load balancer, this depends on the size of the load balancer and the Edge node.
See configuration the following page for details on number of load balancers allowed per Edge node and sizes allowed.
VMware Configuration Maximums for VMware NSX 4.2 Load Balancer.
Use the following API to check the load balancer usage per NSX-T Edge node:GET https://<nsx-t-manager-ip>/api/v1/loadbalancer/usage-per-node/<edge-node-uuid>
Sample result:{ "form_factor": "MEDIUM_VIRTUAL_MACHINE", "edge_cluster_id": "########-####-####-############", "current_credit_number": 10, ----->>>>> This is the number of load balancer credits for a medium NSX-T edge node
"remaining_credit_number": 0, ----->>>>>> This indicates remaining load balancer credits for this medium NSX-T edge node "usage_percentage": 100.0, ----->>>>>> This indicates usage is at 100% "severity": "RED", "current_pool_members": 0, "current_virtual_servers": 1, "current_pools": 0, "current_small_load_balancer_services": 0, "current_medium_load_balancer_services": 1, "current_large_load_balancer_services": 0, "current_xlarge_load_balancer_services": 0, "remaining_small_load_balancer_services": 0, "remaining_medium_load_balancer_services": 0, "remaining_large_load_balancer_services": 0, "remaining_xlarge_load_balancer_services": 0, "remaining_pool_members": 2000, "type": "LbEdgeNodeUsage", "node_id": "########-####-####-####-############"}
Note: The documented configuration maximums may differ, depending on versions, please check for your version.
Once these alarms are validated that the correct size load balancer is on the correct size Edge node, these alarms can be resolved.
Workaround:
Review the VMware Configuration Maximums and confirm the correct sizing is done per Edge node.
If there is a single LB instance (small/medium/large) in an NSX-T Edge Node of same size (small/medium/large); then deploy a new NSX-T Edge Node of a larger size and move the LB instance to that new Edge Node, this will provide extra capacity to add more load balancer instances, if required.
Note: In the case of an XLarge load balancer, only Bare-Metal Edge Nodes support multiple XLarge load balancers, therefore this workaround require Bare-Metal Edge Node in case of multiple XLarge load balancers.
For additional information in relation to the "Read load balancer usage for the given node" API, please see the LbEdgeNodeUsage in NSX REST API Guide: LbEdgeNodeUsage (schema) (Deprecated).
If you are contacting Broadcom support about this issue, please provide the following:
Handling Log Bundles for offline review with Broadcom support
