<Error loading Network Proifles [object Object]>2021-06-13 14:32:15.425 UTC [https-jsse-nio-127.0.0.1-8443-exec-7, Ent: HybridityAdmin, , TxId: TxId: ########-####-####-####-############] ERROR o.a.c.c.C.[.[.[.[dispatcherServlet]- Servlet.service() for servlet [dispatcherServlet] in context with path [] threw exception [Request processing failed; nested exception is com.vmware.hybridity.networking.exception.InternalServerException: VIM NSX mapping not found.] with root cause com.vmware.hybridity.networking.exception.InternalServerException: VIM NSX mapping not found.
VMware HCX
HCX Network Profile (NP) wizard displays network backing from Distributed Switch (DVS), Standard Switch (VSS) & NSX backed logical switch (N-VDS or C-VDS).
IMPORTANT: NSX-T can be registered with multiple vCenters and fetches PGs from all vCenters part of its compute manager. Hence, it displays all PGs/backing in the HCX Network Profile wizard while selecting NSX backed logical switch (N-VDS or C-VDS).
If HCX manager is registered with vCenter (e.g: VC1) and user creates Network Profile using NSX-T backed segments corresponding to a different vCenter (e.g: VC2), HCX manager won't be able to locate & validate that segment with VC1, as a result the Network Profile UI becomes inaccessible post creation.
For all greenfield deployments, the recommendation is to use correct vCenter backed segments/PGs for NSX logical switch during creation of network profile in the HCX NP wizard.
Workaround:
For an existing/brownfield deployment where VC backing is incorrectly set, please open a support case with Broadcom Support and refer to this KB article.
For more information, see Creating and managing Broadcom support cases.
