com.vmware.ssdc.library.exceptions.VimTaskTimeoutException: The vCenter Server operation ([vcId=########-####-####-####-############, moref=task-######) has taken too long (900000.00 seconds). VMware Cloud Director considers this operation timed out. at com.vmware.vcloud.val.taskmanagement.AsynchronousTaskWaitActivity$WaitForInventory/opt/vmware/vcloud-director/logs/vcloud-container-debug.log, messages are seen as:2023-03-17 16:56:23,415 | WARN | vim-proxy-activity-pool-23 | PowerOnVmActivity | [Activity Execution] Timed out while waiting for VMs [[vcId=UUID, moref=vm-####]] status to change to powered on in the inventory cache. Waited 300 seconds for the VMs status to change to > powered on. - Handle: urn:uuid:########-####-####-####-############ | requestId=<REQUEST_UUID>,request=POST https://cloud.example.com/api/vApp/vm-<VM_UUID>/power/action/powerOn,requestTime=1679071877867,remoteAddress=<IP>:60159,userAgent=Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTM...,accept=application/*+xml;version 38.0.0-alpha vcd=<VDC_UUID>,task=<TASK_UUID> activity=(com.vmware.vcloud.backendbase.management.system.TaskActivity,urn:uuid:<TASK_ACTIVITY_UUID>) activity=(com.vmware.ssdc.backend.PowerOnVmActivity,urn:uuid:<TASK_ACTIVITY_UUID>) activity=(com.vmware.vcloud.fabric.foundation.vm.impl.PowerOperationActivity,urn:uuid:<TASK_ACTIVITY_UUID>) activity=(com.vmware.vcloud.val.internal.impl.PowerOnVmActivity,urn:uuid:<TASK_ACTIVITY_UUID>)
VMware Cloud Director 10.6.x
This issue occurs when the DRS setting in the vCenter Server cluster is set to Manual mode.
VMware Cloud Director does not support the power on function of VMs when DRS automation level is set to Manual in vCenter Server.
To resolve the issue, change the vSphere DRS automation level from Manual to Partially Automated or Fully automated on the vSphere cluster(s).
For more details, please refer to the 'vSphere Configuration Requirements' documented in VMware Cloud Director Hardware and Software Requirements.
Japanese Version: VMware Cloud Directorテナントにおける仮想マシンのデプロイおよびパワーオン タスクが失敗する
