/var/log/syslog on Edge:2024-04-17T13:02:01:332Z <Edge hostname> NSX 2359547 - [nsx@6876 comp="nsx-edge" subcomp="node-mgmt" username="root" level="WARNING"] Core file generated: /var/log/core/core.dp-fp:4.1687196169.9076.0.11.gzThis issue is resolved in VMware NSX 3.2.3.1
This issue is resolved in VMware NSX 3.2.4
This issue is resolved in VMware NSX 4.1.1
This issue is resolved in VMware NSX 4.2.0
