Error: "There is not enough space on the file system for the selected operation" when powering on a virtual machine
Article ID: 317513
VMware vSphere ESXi
Symptoms:
Virtual Machine Power-On Failure. The virtual machine fails to power on due to the following issues:
Virtual machine Consolidation Needed warnings are seen.
Insufficient Disk Space: There is not enough space available for the virtual disk.
Datastore running out of space.
Snapshot consolidation failures.
Power-On Failure: The virtual machine could not be started.
Validation:
Virtual machine consolidation needed messages are seen as below:
Click on vCenter >> (Inventory) Virtual Machine>>Summary
You may see insufficient disk space errors as below on your virtual machine and snapshot consolidation failures.
Click on vCenter >> (Inventory) Virtual Machine>> Monitor >>Tasks
Click on vCenter >> (Inventory)Datastore>Summary
VM Power on failures are seen below errors.
VMware vSphere ESXi 7.x VMware vSphere ESXi 8.x
This issue can occur when the device backing the datastore gets full and there is no more space to expand or grow.
Action Required: Expand Datastore or Manage Disk Space
To address this issue, you may follow one of the below actions:
Expand the Datastore: Request an expansion of the datastore to provide additional space.
Free Up Space: Alternatively, delete unnecessary files, migrate the virtual machine disk to another datastore with available space, or consolidate any existing snapshots.
