SASE SD-WAN Edge will not route traffic when a routed LAN interface is configured with 'NAT direct traffic' enabled.
Article ID: 316323
VMware VeloCloud SD-WAN
Symptoms:
- Traffic originated from the same subnet as the routed LAN interface will fail and get dropped as soon as it is received by the edge.
- Traffic from other subnets work fine.
The affected interface has the following properties:
- LAN-facing
- Routed interface
- NAT Direct enabled
This is an expected behavior. Customers are encouraged to disable 'NAT Direct Traffic' for underlay routed LAN connections.
To check if NAT Direct Traffic setting is enabled:
- Go to Configure > Edge > Device Tab > Interfaces
- Click on the affected interface.
- Confirm if NAT Direct Traffic is enabled for the LAN interface, and uncheck it if necessary.
Example:
Feedback
thumb_up
Yes
thumb_down
No
