Dell Power Edge Server (HOST) reports Temperature Sensor OutofRange alerts when current value is below high threshold. The Notification Properties show Lower Critical and Upper Critical Thresholds as shown below.
If the Dell Power Edge System have these tempsensors instrumented by TemperatureSensor_Fault_DellPowerEdge then they have a low threshold LowerCriticalThreshold.and a HighCritical Sensor
