The vSAN build recommendation engine leverages the VMware Update Manager (VUM), the vSAN hardware compatibility list (HCL), and the vSAN release catalog to provide upgrade baselines for individual vSAN clusters. The vSAN HCL does not cover all hardware components in a server. The only components that are being taken into consideration for the compatibility check are:
- Storage Controllers
Other components, such as the NICs, CPUs, or server itself, are not being evaluated against the VMware VSAN HCL.
