The VM Fails to Power On Due to "System Cannot Find the File Specified" or Other "File Not Found" Errors
Article ID: 315391
VMware vSphere ESXi
  • This article provides solutions for situations where a virtual machine (VM) fails to power on due to missing or invalid virtual machine disk (VMDK) descriptor files or snapshot chain issues.
  • The virtual machine cannot power ON and reports errors about missing files or disk dependencies. The error typically involves missing VMDK descriptor or data files, or an inconsistent snapshot chain.
  • The errors typically encountered include:
    "Cannot open the disk '/vmfs/volumes/volume/vm/vm-000002.vmdk' or one of the snapshot disks it depends on."
    "Cannot open disk '/vmfs/volumes/volume/vm/vm-000002.vmdk': The parent virtual disk has been modified since the child was created (18)."
    The following error can be seen in the vSphere Client > VM > Monitor > All Issues: "Some of the disks of the virtual machine vm_name failed to load. The information present for them in the virtual machine configuration may be incomplete."
  • In the VM's vmware.log, messages similar to below can be seen:
    vmx| DISKLIB-LINK : "myvm.vmdk" : failed to open (The system cannot find the file specified).
    vmx| DISKLIB-CHAIN : "myvm.vmdk" : failed to open (The system cannot find the file specified).
    On validating the files in the VM folder, one or more disk descriptor or data files are missing.
VMware vSphere ESXi 8.x
VMware vSphere ESXi 7.x
These errors can occur due to:
  • Missing or corrupted virtual machine disk (VMDK) descriptor or data files.
  • Inconsistent snapshot chains where a child disk depends on a missing or modified parent disk.
Note: The below steps can be destructive, kindly ensure valid backup for VM is available before proceeding.
  1. Verify the presence of Virtual Machine Disk Files
  2. For each disk, including snapshot disks, verify that the following files are present:
    • Base Disk Descriptor File: vmName.vmdk
    • Base Disk Data File: vmName-flat.vmdk or vmName-separse.vmdk
    • Snapshot Disk Descriptor File: vmName-######.vmdk for each snapshot.
    • Snapshot disk data file: vmname-######-delta.vmdk or vmname-######-sesparse.vmdk for each snapshot.
    • If any of these files are missing, the disk may need to be recreated or restored.
  3.  Recreate Missing Descriptor File:
  4.  Missing Data File:
    • If data files, such as -flat.vmdk, -delta.vmdk, or -sesparse.vmdk files are missing, the VM may need to be restored from a backup or the original data source.
  5. Check for Inconsistent Snapshot Chains:
    • If errors regarding "The parent virtual disk has been modified since the child was created" is encountered it may be needed to consolidate the snapshot chain or restore the VM from a backup.
