This is a known issue affecting VMware Site Recovery Manager 6.0 and 6.1.x.
To work around this issue, use one of these options:
Option 1
- Disable CTK on the primary VM.
- Reconfigure the Replication.
- Re-add to the SRM PG.
To disable ctk on the VM, complete the following steps:
- Pause the Replication status of the VM
- Remove the VM from the SRM PG and RP.
- Ensure that there are no snapshots on the source virtual machine.
To disable CBT:
- Power off the virtual machine.
- Right-click the virtual machine and click Edit Settings.
- Click the Options tab.
- Click General under the Advanced section and then click Configuration Parameters. The Configuration Parameters dialog opens.
- Set the ctkEnabled parameter to false for the desired SCSI disk(s).
- Power on the source virtual machine.
4. Enable the Replication status from vSphere Replication View to continue the replication of the virtual machine
Option 2 Use vmdk's of size less than 2TB.
