Best practices and advanced features for vSphere High Availability
Article ID: 313917
VMware vCenter Server 6.0 VMware vCenter Server 8.0 VMware vSphere ESXi
This article provides information on best practices and advanced features for a vSphere High Availability (HA) environment.
Each new version of Virtual Center Server provides new features that you can configure to change how VMware HA functions. You can configure the features using the VMware Infrastructure (VI) Client.
This section lists the features available in each version of vCenter Server:
vCenter Server 8.0.x
vCenter Server 7.0.x
vCenter Server 6.7.x
Best Practices for VMware HA Clusters information is provided in the vSphere 6.7 vSphere Legacy Releases .
vCenter Server 6.5.x
Best Practices for VMware HA Clusters information is provided in the vSphere 6.5 vSphere Legacy Releases.
For a detailed description of how vSphere High Availability works, see How vSphere HA works
For more information on best practices and when to consider configuring the new features, see the Appendix section in the document 1002080_HA_Best_Practices.pdf attached to this article (VMware HA: Overview & Technical Best Practices).
1002080_HA_Best_Practices.pdf get_app
