Disassociate Aria products from SDDC Manager
Article ID: 313436
VMware Cloud Foundation VMware vSphere ESXi
  • This article provides the steps to remove one or more Aria products from SDDC Manager without actually deleting their Virtual Machine or configuration in vCenter or NSX.
  • This script can also fully delete vRSLCM from SDDC Manager and vCenter.
VMware Cloud Foundation 4.x
VMware Cloud foundation 5.x
Follow the below mentioned steps to disassociate Aria product from SDDC Manager or for fully deleting vRSLCM.
  1. Download the script "eject_vrs_delete_vrslcm.sh" to the SDDC Manager Virtual Machine.
  2. Copy the script using WinSCP to /home/vcf directory in SDDC Manager
  3. Take a snapshot of SDDC Manager VM
  4. SSH to SDDC Manager with vcf user and su to root
  5. Provide permissions to execute the script
    chmod 777 /home/vcf/eject_vrs_delete_vrslcm.sh
    eject_vrs_delete_vrslcm.sh echo "Description of the script options here."
    The output displayed will be:
    echo -h | --help Displays help menu
    echo -wsa Disassociate WSA from SDDC Manager
    echo -vra Disassociate VMware Aria Automation from SDDC Manager
    echo -vrops Disassociate VMware Aria Operations from SDDC Manager
    echo -vrli Disassociate VMware Aria Operations for Logs from SDDC Manager
    echo -all Disassociate all VMware Aria products from SDDC Manager
    echo -delete_vrslcm Fully deletes VMware Aria Suite Lifecycle Instance and Tier 1 Gateway
  6. Choose your option and execute the script
    Note:
    Running the command by including echo will not work.
    Remove "echo" in the command, and run the following instead:
    eject_vrs_delete_vrslcm.sh -"Description of the script options here."
    For Example:
    For deleting vrops
    ./eject_vrs_delete_vrslcm.sh -vrops
    For deleting vrslcm
    ./eject_vrs_delete_vrslcm.sh -delete_vrslcm
  7. When prompted for:  provide credentials of SDDC Manager Instance, i.e., <[email protected]>
eject_vrs_delete_vrslcm get_app
