Virtual machine does not power on when there is high CPU reservation
Article ID: 313075
VMware vCenter ServerVMware vSphere ESXi
Unable to power on virtual machine
The following error messages are displayed:
CPU min outside valid range
Invalid CPU allocation requested for VM
A message similar to the following may be reported in /var/log/vmware/hostd.log
msg = 'Group host/user: Invalid cpu allocation requested for VM vmm0:VM1. (min: 6400 mhz, max: 4294967295, minLimit: 4294967295, shares: 4294967292)\nCould not power on VM : CPU min outside valid range.\nFailed to power on VM', faultCause = <unset>, faultMessage = (vmodl.LocalizableMessage) [], reason = 'Group host/user: Invalid cpu allocation requested for VM vmm0:VM1. (min: 6400 mhz, max: 4294967295, minLimit: 4294967295, shares: 4294967292)\nCould not power on VM : CPU min outside valid range.\nFailed to power on VM', messageInfo = (vim.vm.Message) []
VMware vSphere ESXi 6.x VMware vSphere ESXi 7.x VMware vCenter Server 7.x VMware vCenter Server 6.x
This issue occurs if the CPU min value is outside the valid range that the PCPU cannot serve.
The CPU min value may become invalid if:
The virtual machine was migrated from one host to another and PCPU capacity of the destination host is less than that of the source host.
The PCPU values were changed after the virtual machine was created and the current PCPU capability is insufficient to meet the virtual machine requirements.
To resolve this issue: a. Using the vSphere Client b. Using the ESXi shell
vSphere Client:
Connect to the ESX or vCenter Server host with appropriate administrative credentials.
Select the virtual machine from the inventory.
Right-click on the virtual machine and click Edit Settings.
On the Virtual Machine Properties dialog, click the Resources tab.
Select CPU from list under the Settings column.
Use the slider or the Reservation text box to lower the CPU reservation value.
