This issue can be caused by one or more reasons below:
Failed to power on virtual machine
Workaround:
Note: If your vCenter Server has been running for more than 120 days, it is best practice to perform updates to the vCenter Server OS if any are available for that vCenter Server version. This process will also require a reboot of the vCenter.
Keeping to that update regimen can reduce the occurrence of many issues such as the VM power-on/off appearing greyed out.
