Entering maintenance mode on NSX-T Edge nodes from CLI
Article ID: 311846
VMware NSX VMware vSphere ESXi
If NSX manager lost the connection to the Edge, and the Edge remains in NSX maintenance mode. You can exit the NSX maintenance mode using the CLI option.
VMware NSX
VMware NSX-T Data Center 3.x
Run the command below from Edge admin mode to trigger an exit of NSX edge maintenance mode.
edge> set debug-mode
edge> set maintenance-mode disabled
Example of command execution :
This command has been deprecated and not recommended for use. Please use API/UI to configure this setting.
Are you sure you want to continue? (yes/no):yes
Maintenance Mode: disabled
edge>
Run the "get maintenance-mode" command to validate the status of Maintenance Mode.
edge> get maintenance-mode
Mon Mar 03 2025 UTC 05:51:27.094
If you need to place the Edge into maintenance mode again, run the command below.
edge> set maintenance-mode enabled
Maintenance Mode: enabled
edge>
Mon Mar 03 2025 UTC 05:56:11.830
Note: set maintenance-mode is only available using debug-mode. Once in maintenance mode via CLI, the Edge must be taken out of maintenance mode via CLI.
Status of Edge in NSX GUI:
