Changing Beacon Probing settings using the command line
Article ID: 311349
VMware vSphere ESXi
This article describes changing Beacon Probing using the command line. This changes network settings for Network Failure Detection from Link Status Only to Beacon Probing for the vSwitch, virtual machine network, and Service Console.
VMware vSphere ESXi 6.x
VMware vSphere ESXi 7.x
VMware vSphere ESXi 8.x
  • To set vSwitch0 to Beacon Probing, run the command:
    esxcli network vswitch standard policy failover set -f beacon -v vSwitch0
  • To set vSwitch0 to Link Status Only, run the command:
    esxcli network vswitch standard policy failover set -f link -v vSwitch0
  • To verify the setting changes, run the command:
    esxcli network vswitch standard policy failover get -v vSwitch0
    You see output similar to:
    Load Balancing: srcport
    Network Failure Detection: beacon <<<<<
    Notify Switches: true
    Failback: true
    Active Adapters: vmnic1
    Standby Adapters:
    Unused Adapters:
At least 3 or more physical NICs in the team connected to 3 separate physical switches must be assigned to the NIC TEAM to successfully configure Beacon probing, otherwise you see an error similar to:
(vmodl.fault.InvalidArgument)
dynamicType = <unset>,
invalidProperty = <unset>,
msg = "A specified parameter was not correct."
For more information on Beacon Probing, see What is beacon probing?
