Using SRAM With Dynamic Calls with VISION:Results
Article ID: 31103
Updated On: 11-19-2024
Vision:Results
SRAM can be used with programs, applications, and products that use dynamic calls.
The calling program is not required to statically linked SRAM's SRAMASCB module for dynamic calls.
All that is required is that the CALL entries be link-edited to the SRAMASCB module as an ALIAS.
For instance, following SRAM  CALL entries:
  • SRTOPEN or CAOPN
  • SRTFILL or CAFIL
  • SRTGETR or CAGET
  • SRTCLSE or CACLS
  • SRTROPN or CAROP
would be linked to SRAMASCB as follows:
//IEWL  EXEC PGM=IEWL,REGION=2048K,
//             PARM='MAP,LET,LIST,NCAL'
//SYSLIB   DD  DSN=CAI.SRAMLIB,DISP=SHR
//SYSLMOD  DD  DSN=CAI.SRAMLIB,DISP=SHR
//SYSLIN   DD  *
INCLUDE SYSLIB(SRAMASCB)
ALIAS    SRTOPEN
ALIAS    SRTFILL
ALIAS    SRTGETR
ALIAS    SRTCLSE
ALIAS    SRTROPN
NAME SRAMASCB(R)
//SYSUT1   DD  UNIT=SYSDA,SPACE=(CYL,(1,1))
//SYSPRINT DD  SYSOUT=*
VISION:Results can then be used with SRAM:
OPTION STRUCTURED2 QLF
FILE ARFILE STATUS EOFILE
ARREC   352   1
ACCOUNT   7   4  CH
BALANCE   5 170  PD 2 A
FILE ININ F 80 DUMMY
WORKAREA
SRAMPARM 56   1
DDNAME    8   1  CH VALUE   'SRAMWORK'
CORE      4   9  BI VALUE  X'00040000'
RECLEN    2  13  BI VALUE   352
MODESRT   2  15  BI VALUE  X'FFFF'
KEYFLD   40  17  CH VALUE   '(4,7,CH,A,170,5,PD,A)'
WORKAREA NAMED SRAM
RECAREA 352   1
FINDEOF   2   1  BI
ACCOUNT   7   4  CH
NAME     26  11  CH
CALL SRTOPEN USING SRAMPARM          ; OPEN SRAMWORK FILE
READINF:
READ ARFILE
IF EOFILE EQ 'E'
  GOTO SORTREC
ENDIF
MOVE ARREC TO RECAREA
CALL SRTFILL USING SRAMPARM RECAREA  ; FILL SRAMWORK WITH A RECORD
GOTO READINF
SORTREC:
MOVE MODESRT TO FINDEOF
MOVE X'FFFFFFFFFFFFFF' TO SRAM.ACCOUNT  ; HIGH VALUES TO SORT KEY
CALL SRTFILL USING SRAMPARM RECAREA  ; FILL SRAMWORK WITH EOF RECORD
READSORT:
CALL SRTGETR USING SRAMPARM RECAREA  ; GET SRAMWORK SORTED RECORD
IF FINDEOF EQ MODESRT
  CALL SRTCLSE USING SRAMPARM        ; CLOSE SRAMWORK FILE
  GOTO REOPSORT
ENDIF
LIST SRAM.ACCOUNT SRAM.NAME SRAM.BALANCE
GOTO READSORT
REOPSORT:
CALL SRTROPN USING SRAMPARM          ; REOPEN SRAMWORK FILE
READAGN:
  STOP
ENDIF
PRINT RECAREA
GOTO READAGN
T1 'SRAM EXAMPLE'
T1+2  DYLDATE4
T1+90  DYLPAGE
