Article ID: 310939
VMware ESXi 4.0.x Embedded
VMware ESXi 4.1.x Embedded
VMware ESXi 4.0.x Installable
VMware ESX 4.1.x
VMware ESXi 4.1.x Installable
VMware ESX 4.0.x
If this issue occurs again after rebooting the virtual machine, collect diagnostic information and file a support request with VMware Technical Support:
- Collect diagnostic information, including performance snapshots. For more information, see Collecting performance snapshots using vm-support (1967).
- Take a copy of the virtual machine.
- Collect any other pertinent data.
Note: If you can reproduce the issue and you are not already running a debug monitor, follow the steps in the error message to run a debug monitor and update your support request with this information.
- File a support request with VMware Technical Support and note this Knowledge Base article ID (1030383) in the problem description. For more information, see Filing a Support Request in Customer Connect (2006985) or How to Submit a Support Request.
