A replicated virtual machine using multiple datastores fails to start with the vCenter Server error: .vmdk file is locked
Article ID: 310911
Updated On: 03-20-2024
VMware vSphere ESXi
Symptoms:
  • A replicated virtual machine using multiple datastores fails to start
  • You see the vCenter Server message:
VMware ESX 4.0.x
VMware ESXi 4.1.x Installable
VMware ESXi 4.1.x Embedded
VMware ESXi 4.0.x Embedded
VMware ESXi 4.0.x Installable
VMware ESX 4.1.x
This issue can be occur in two scenarios:
  • One of the LUNs and its .vmdk were not replicated, so a placeholder hard disk filename is showing in vSphere Client. In Edit Settings in vSphere Client, hard disk 2 looked like the Hard Disk 1 on the main datastore of the virtual machine.
  • The datastore of a LUN that was replicated and resignatured has a different UUID and the *.vmx file still points to the old datastore UUID. As a result, a placeholder hard disk file name shows up in vSphere Client and in Edit Settings, hard disk 4 looks like hard disk 3 on the main datastore of the virtual machine.
Several LUNs formatted with VMFS have been replicated on the same array or from one array to another. Upon presenting LUNs to a new host, the host detected LUNs as snapshots so they were resignatured via Add Storage in vCenter Server.
To resolve the first scenario:
  1. From the inventory of the virtual machine, remove all virtual hard disks that have a duplicate name of disks in the main datastore associated with the virtual machine.
  2. Create a new virtual hard disk in the new datastore while maintaining the old SCSI node ID.
To resolve the second scenario:
  1. From the inventory of the virtual machine, remove virtual hard disks that have a duplicate name of disks in the main datastore associated with the virtual machine.
  2. Re-add the existing virtual hard disks from a new, replicated datastore while maintaining the old SCSI node ID.
