Article ID: 309844
Symptoms:
- V2V conversion using vCenter Converter 4.2.x or vCenter Converter Standalone 4.3.x fails at random times during disk cloning
- In the Converter logs, you see entries similar to:
[#24] [2011-03-19 00:17:57.071 05200 error 'task-12'] get unknown disk controller type
[#24] [2011-03-19 00:17:57.105 05200 error 'task-12'] managed to managed disk clone failed: unknown disk controller type
[#24] [2011-03-19 00:17:57.105 05200 error 'task-12'] Disk clone failed with clone error unknown disk controller type
Disk controller type can be verified by searching for the following in the converter logs:
--(vim.vm.device.ParaVirtualSCSIController) {
[#37] dynamicType = <unset>,
[#37] key = 1000,
[#37] deviceInfo = (vim.Description) {
[#37] label = "SCSI controller 0",
[#37] summary = "VMware paravirtual SCSI",
virtual-machine-scsi-controller-type
VMware vCenter Converter 4.2.x
VMware vCenter Converter Standalone 4.3.x
VMware is aware of this issue and has scheduled to resolve it in a future release.
To workaround this issue:
- Change the disk controller type to LSI logic or Buslogic before conversion.
- Revert the SCSI controller type to Paravirtual after the conversion completes.
For more information, see Changing the virtual SCSI controller of a virtual machine (1002149).
