Audit logging of vShield Edge does not work correctly in vShield Manager 5.1
Article ID: 309252
VMware vSphere ESXi
Symptoms:
  • Audit logging for vShield Edge does not work properly in vShield Manager 5.1.
    Note: The requests are audit-logged as success as soon as they are stored in the database and before they are successfully applied to the vShield Appliance. If the requested configuration failed to apply on the vShield Appliance, it is not reflected in the audit log.
  • Requests rejected on syntactic validations are no longer audit logged.
VMware vShield Edge 5.1.x
VMware vShield Manager 5.1.x
This is a known issue.
Currently, there is no workaround for this issue.
To be alerted when this document is updated, click the Subscribe to Article link in the Actions box vShield Edgeの Auditログが、vShield Managerで正常に動作しない。
