This issue is resolved in VMware NSX for vSphere 6.2.5 and NSX for vSphere 6.3.0
Note: The resolved versions resolves the issue for newly deployed Edges only. The work around must be applied for all the existing Edges that will be upgraded.
To work around this issue if you do not want to upgrade, ensure that the NSX Edge virtual machine is not configured in the Auto Startup/Shutdown configuration.
Using the vSphere Client
- Log in to the vCenter Server.
- Navigate to the ESXi host where the NSX Edge virtual machine resides.
- Click the Configuration tab.
- Select Virtual Machine Startup/Shutdown under Software.
- Click Properties.
- Ensure that the NSX virtual machine is not added to the Automatic Startup/Shutdown.
For example, ensure that the virtual machine is in Manual mode.
Using the vSphere Web Client
- Log in to vCenter Server.
- Click Manage > Settings.
- Under Virtual Machines, select VM Startup/Shutdown and click Edit.
- Ensure the NSX virtual machine is not added to the Automatic Startup/Shutdown.
