When using BGP on NSX Edge appliance, errors can be observed similar to:Jan 10 01:14:06 edge-01-0 routing[1007]: PROBLEM 0x0303-25 (0000): A connection attempt has failed
This issue occurs when the edge is trying to establish a TCP/IP connection to a defined peer, but it is not able to do so on IP level.
Check the routing logging by running the below command on Edge to see which peer has problems:show log routing reverse
the output could contain similar to the following:
"...#### PROBLEM 0x0303 - 25 (0000) ##### -:-------- F:00000001sckorig2.c 1366 :at 01:05:11, 10 January 2017 (102688190 ms)A connection attempt has failed.Sockets error code = 113Socket ID = 19Socket type = 0X00000001Socket family = 0X00000002Socket protocol = 0X00000000Application handle = 0X01DF0000Stub socket handle = 0X02A50004Local inet address = 0.0.0.0Local port = 0Remote inet address = #.#.#.#Remote port = 179
Check the ARP table on the Edge and look for the above IP :show arp
Check if you are able to reach the peer from the Edge with ping :ping <peer_IP>
If ping fails or ARP table does not show the MAC address of the remote address, check the physical path.
