Cannot power on a virtual machine after enabling vSphere Replication
Article ID: 307318
VMware Live Recovery VMware vSphere ESXi
Symptoms:
  • You are unable to power on a virtual machine after enabling vSphere Replication.
  • When you attempt to power on the virtual machine, you see an error similar to:
    Failed to start the virtual machine.
    Module DevicePowerOn power on failed.
    Unable to create virtual SCSI device for scsi0:1, '/vmfs/volumes/4ffda1f1-########-####-##########ff/example/example.vmdk'
    Failed to attach filter 'hbr_filter' to scsi0:1: Limit exceeded (195887110).
VMware vSphere Replication 5.1.x
vSphere Replication 5.1 and earlier supports disks up to 2032 GB in size. Virtual machines with larger disks are unable to power on after enabling vSphere Replication.
To resolve this issue, disable vSphere Replication on the virtual machine using one of these methods:
vSphere Replication 5.5 supports a maximum disk size of 62 TB.
To be alerted when this document is updated, click the Subscribe to Article link in the Actions box
How to stop, start, or restart vCenter Server services
