This article describes a specific issue. If you experience all of the above symptoms, consult the sections below. If you experience some but not all of these symptoms, your issue is not related to this article. Search the Knowledge Base for your symptoms, or
Open a Support Request.
Symptoms:
- High Availability (HA) does not failover a virtual machine if Storage vMotion is in progress for that virtual machine
- In the vpxd logs of vCenter Server, you see entries similar to:
vpxd-327.log:2012-01-24T07:17:20.884Z [02652 error 'VmProv' opID=AC12180D-0000134C-d7-45] error while tracking VMotion progress (vmodl.fault.HostCommunication)
vpxd-327.log:2012-01-24T07:17:22.243Z [02652 error 'VmProv' opID=AC12180D-0000134C-d7-45] [VMOTION_RECOVER] Failed to initiate VMotion on hosts: vmodl.fault.HostCommunication
vpxd-327.log:2012-01-24T07:17:22.243Z [02652 verbose 'vmprovvpxdTxnManager' opID=AC12180D-0000134C-d7-45] [VMOTION_RECOVER] VpxdTxnManager received request to mark VM ID vm-464 with state 2, src URL ds:///vmfs/volumes/4c51f5f2-6251c5b5-9b55-002219348b1a/SwingBench_Client_XP_1/SwingBench_Client_XP.vmx, dest URL ds:///vmfs/volumes/4c84767c-43c38bdc-a705-0024e850729a/SwingBench_Client_XP_2/SwingBench_Client_XP.vmx
vpxd-327.log:2012-01-24T07:17:23.102Z [02652 info 'VmProv' opID=AC12180D-0000134C-d7-45] [WorkflowXAction] Starting workflow rollback
vpxd-330.log:2012-01-24T07:22:15.554Z [02652 error 'VmProv' opID=AC12180D-0000134C-d7-45] [VMOTION_RECOVER] Failed to complete vmotion on hosts: vmodl.fault.HostCommunication
vpxd-331.log:2012-01-24T07:22:58.724Z [02652 info 'VmProv' opID=AC12180D-0000134C-d7-45] [WorkflowXAction] Caught exception vmodl.fault.HostCommunication while undoing action vpx.vmprov.CreateDestinationVm
vpxd-331.log:2012-01-24T07:23:19.957Z [02652 error 'DAS' opID=AC12180D-0000134C-d7-45] [VpxdDas::PostMigrateCallback] MarkSVmotionDone failed on host [vim.HostSystem:host-102,w1-fi040.eng.vmware.com] for VM /vmfs/volumes/4c51f5f2-6251c5b5-9b55-002219348b1a/SwingBench_Client_XP_1/SwingBench_Client_XP.vmx : class Vmomi::Fault::HostCommunication::Exception(vmodl.fault.HostCommunication). Skip
vpxd-331.log:2012-01-24T07:23:21.785Z [02652 info 'commonvpxLro' opID=AC12180D-0000134C-d7-45] [VpxLRO] -- FINISH task-internal-810605 -- -- VmprovWorkflow -- ^M
vpxd-331.log:2012-01-24T07:23:21.785Z [02652 info 'Default' opID=AC12180D-0000134C-d7-45] [VpxLRO] -- ERROR task-internal-810605 -- -- VmprovWorkflow: vmodl.fault.HostCommunication:
- In the /var/log/fmd.log file of the cluster Fault Domain Manager (FDM) master, you see entries similar to:
2012-01-24T07:21:14.911Z [7935DB90 verbose 'Cluster' opID=host-30:3-53-SWI-8b9851f8] [ClusterDatastore::CheckIfPowerOffFileExistsWork] Checking for /vmfs/volumes/4c51f5f2-6251c5b5-9b55-002219348b1a/SwingBench_Client_XP_1/SwingBench_Client_XP.vmx
2012-01-24T07:21:14.916Z [7935DB90 verbose 'Cluster' opID=host-30:3-53-SWI-8b9851f8] [ClusterDatastore::CheckIfPowerOffFileExistsWork] /vmfs/volumes/4c51f5f2-6251c5b5-9b55-002219348b1a/SwingBench_Client_XP_1/SwingBench_Client_XP.vmx not found
2012-01-24T07:21:14.917Z [7935DB90 info 'Execution' opID=host-30:3-53-SWI-8b9851f8] [FailoverAction::PowerOffFileCheckCompletion] Aborting failover. vm /vmfs/volumes/4c51f5f2-6251c5b5-9b55-002219348b1a/SwingBench_Client_XP_1/SwingBench_Client_XP.vmx cleanly powered off and no power-off file. Assuming user power off
- The virtual machine is in a disconnected state and does not power on correctly after the HA event
