Events generated for Power Supply on Cisco devices
Article ID: 303980
VMware Smart Assurance
Symptoms:
What events are generated in Smarts for power supply issues on Cisco devices?
Status of power supply is shown as UNKNOWN in Smarts containment tab when the power supply is removed
SMARTS 10.1.x
Smarts only generates a StateNotNormal event when the ciscoEnvMonSupplyState OID reports a status of Warning, Critical, notFunctionning or Shutdown (see Fix statement). When a power supply is removed (status 5:notPresent), Smarts returns UNKNOWN status for the power supply.
To poll power supply state on Cisco devices, Smarts uses the ciscoEnvMonSupplyState OID ( 1.3.6.1.4.1.9.9.13.1.5.1.3 ) from the  CISCO-ENVMON-MIB. The following shows the status possibilities of this OID:
OID 1.3.6.1.4.1.9.9.13.1.5.1.3
Type CiscoEnvMonState
1:normal
2:warning
3:critical
4:shutdown
5:notPresent
6:notFunctioning
