How to work around my issue in NSX for vSphere?
Article ID: 303276
VMware NSX
This article is intended to document commonly used workarounds to resolve an issue with your NSX for vSphere (NSX-v) environment. Please refer to the section that describes best your current situation.
Note: This article does not supersede documented workarounds for specific issues documented in KB articles or release notes. If you encounter an issue that is documented, use the associated workaround, if any.
NSX-v Manager is unresponsive
  • Reboot the NSX-v Manager appliance.
    • From its VM console:
      enable
      reboot
    • or from the ESXi host running the appliance,
    • or from vCenter.
  • Or restore the NSX-v Manager from backup. See documentation.
NSX-v Manager shows high CPU utilization
    • From its UI,
    • or from its VM console:
      • enable
      • reboot
    • or from vCenter.
NSX-v Manager cannot be upgraded
  • Use alternative upgrade procedure:
  1. Complete an FTP backup on the current NSX Manager.
  2. Shut down current NSX Manager. (Do not delete it at this stage.)
  3. Deploy a new NSX-v Manager in same version, from the OVA. (Ensure that both NSX Managers are NOT online at the same time.)
  4. Restore the FTP backup in the new NSX-v Manager.
  5. Complete the upgrade in the new NSX-v Manager with the upgrade file.
NSX-v Controller is disconnected
  • Restart the clustering process on the NSX-v Controller appliance:
    • Via SSH: restart controller
    • or from its VM console: restart controller
  • Or reboot the NSX-v Controller appliance:
    • Via SSH: restart system force
    • or from its VM console: restart system force
    • or from vCenter.
  • Or redeploy the NSX-v Controller. See documentation.
NSX-v Controller Cluster is unhealthy
NSX-v Controller Cluster cannot be upgraded
NSX-v Edge is unresponsive or unhealthy or services stopped working (BGP, VPN, etc.)
  • Force sync the NSX-v Edge. See documentation.
  • Or reboot the NSX-v Edge appliance:
    • From the ESXi host running the appliance,
    • or from vCenter.
  • Or redeploy the NSX-v Edge appliance. See documentation.
NSX-v Edge cannot be upgraded
    • Documented workaround from KB57183.
NSX-v Guest Introspection is unhealthy
  • Redeploy Guest Introspection.
NSX-v related issues on an ESXi host (DFW, VXLAN, GI, VIB upgrade, etc.)
  • Force sync services. See documentation.
  • Or reprepare the ESXi host for NSX-v:
  1. Drag the ESXi host out of the cluster.
  2. Reboot the ESXi host.
  3. Drag the host back into the cluster.
  • If the ESXi host fails to install NSX-v VIBs, reimage the ESXi host.
vSphere cluster preparation cannot be upgraded in NSX-v
  1. Create a new Cluster.
  2. Prepare the new Cluster with newer NSX-v version.
  3. Drag the first ESXi host out of the old cluster.
  4. Reboot the ESXi host.
  5. Drag the ESXi host in the new cluster.
  6. Repeat for all ESXi hosts in the old cluster.
VM traffic is incorrectly affected by NSX-v DFW
  • Temporarily add the affected VM to the DFW exclusion list. See documentation.
Issues with NSX-v features
NSX-v Troubleshooting Guide
The NSX-v release notes document workarounds for more specific issues
