Problem to read the password data using SDK DMS API DmsApiSample.java
Article ID: 30073
Updated On: 10-17-2023
CA Single Sign On Secure Proxy Server (SiteMinder) CA Single Sign On SOA Security Manager (SiteMinder) CA Single Sign-On SITEMINDER
Using sdk\samples\javadmsapi\DmsApiSample.java to get a user's password state (SmDmsUserPWState).
Problem to read the password data from a Linux Policy Server.
Works fine with a Windows Policy Server.
Not the same Policy Server / Encryption Key used to encrypt and decrypt the password data (blob) information.
When trying to retrieve it, always the same date.
  • Make sure, when using multiple Policy Servers, to use the same Encryption Key.
