Not able to encrypt secrets using SCS 3.x with Git
Article ID: 297138
Support Only for Spring
When making a POST request to the /encrypt endpoint of a config-server, it gives the following error for both normal and admin users:
Bearer error="insufficient_scope", error_description="The token provided has insufficient scope"
There is a known bug where this error will happen when there are many spaces accessible to the user in the PCF foundation.
You can confirm you are hitting this issue by runningcf curl /v2/spaces | jq .total_pages. If the response is greater than one ( > 1 ), you are impacted.
Note: If you do not have jq installed, you can leave off that part of the command and look in the response JSON for the total_pages value.
This issue is fixed in Spring Cloud Services (SCS) 3.1.10. Upgrade to SCS 3.1.10 or later version to resolve this issue.
