Sensor in Bypass Mode and Not Showing in Carbon Black Cloud Console After Install
Article ID: 291348
Carbon Black Cloud Endpoint Standard (formerly Cb Defense)
Carbon Black Cloud Enterprise EDR (formerly Cb Threathunter)
After installing the sensor it immediately goes into bypass mode and never registers with the Carbon Black Cloud Console
- Carbon Black Cloud Sensor: All Supported Versions
- Linux: All Supported Versions
The COMPANY_CODE wasn't used during install
- Run the command sudo /opt/carbonblack/psc/bin/cbagentd -d '<COMPANY_CODE>'
- Restart the sensor
Feedback
thumb_up
Yes
thumb_down
No
