All Products: Which CB Products Can Block USB Device Access
Article ID: 291326
Carbon Black App Control (formerly Cb Protection) Carbon Black Cloud Endpoint Standard (formerly Cb Defense) Carbon Black EDR (formerly Cb Response)
Which VMware Carbon Black products can be used to block USB device read and write access?
  • Endpoint Standard Sensor:
    • Windows: 3.6.0.1897 and Higher
    • Apple macOS: 3.5.3.82 and Higher
  • EDR Sensor: All Versions
  • App Control: All Versions
  • Microsoft Windows: All supported versions
  • Apple macOS: All supported versions
  • App Control (formerly CB Protection) can restrict USB activity including read and write access.
  • Carbon Black Cloud can restrict USB activity including read and write access on Windows endpoints with version 3.6.0.1897 and Higher and macOS endpoints with version 3.5.3.82 and Higher
  • Carbon Black Cloud does not offer USB blocking on Linux devices
  • EDR can detect but not block USB device access
