How to test connectivity using OS's built in cURL?
Article ID: 288866
Carbon Black Cloud Endpoint Standard (formerly Cb Defense)
Show More
Show Less
Carbon Black Cloud Console: All versions Carbon Black Cloud Linux Sensor: All versions Carbon Black Cloud Mac Sensor: All versions Apple macOS: All supported versions RHEL/Cent OS: All supported versions Ubuntu: All supported versions SUSE: All supported versions Amazon Linux: supported versions Windows Server: 2019 and newer supported versions Windows 11: All supported versions Windows 10: Version 1804 (April 2018 Update) and newer supported versions
Depending on your OS, open a Command Prompt, Console, or Terminal
Run:
curl https://dev-prod05.conferdeploy.net/services/healthCheck/
If successful you should have an output similar to:
C:\>curl https://dev-prod05.conferdeploy.net/services/healthCheck/
{"appStats":{"Commit":"d601d631","Build":"1.23.3","Branch":"v1.23.3"},"message":"success","success":true}
This will work even if the CBC agent is not install, and can be use for non Carbon Black related URLs.
The --verbose | -v option. cURL will show additional information. If you think this option still does not give you enough details, consider using --trace or --trace-ascii instead:
curl --verbose https://dev-prod05.conferdeploy.net/services/anything
If you use the --insecure | -k option cURL will skip the verification of the certificate:
curl --insecure https://dev-prod05.conferdeploy.net/services/anything
For more information about cURL, reference the man page .
Feedback
thumb_up
Yes
thumb_down
No
