Difference between Direct and Indirect Costs
Article ID: 283900
CloudHealth
Many reports are split into two types of costs:
  • Direct Cost: These costs have a resource ID or asset ID associated with them.  The platform can attribute these costs to an asset or resource and can therefore allocate them to a Perspective group.
  • Indirect Cost: These costs are not associated with a resource ID or an asset ID. Support costs are an example of indirect cost.  Therefore, they cannot be attributed to groups.
The platform classifies an AWS or Azure Service as a Direct Cost or Indirect Cost.  When AWS or Azure introduces a service, the platform initially classifies the service cost as an Indirect Cost.  When support for that service is eventually built into the the platform, the service cost becomes a Direct Cost that can be allocated to Perspective Groups.
