Using Fonts for Presenting Aion
Article ID: 28284
Aion Business Rules Expert
How do you use Fonts for Presenting Aion?
Release: 9.5
Component: Aion-Business Rules-Advanced Builder Option
When demonstrating the Aion product to your co-workers for training or demo purposes, don't forget to use the Font setting capabilities of the Aion IDE and debugger to make the text more readable by the audience. You can set font sizes for the Method editor, Decision Table editor, debugger, and Image Lists and Tree Lists (ie. workspace, explorer, output window, etc.). See the TOOLS.FONTS option in the IDE and play around with different font sizes to see how it looks. NOTE:  Most of the editor font changes are not reflected until the editor is closed and reopened.
For the debugger, see the View.Settings screen option to set font sizes. You can also change the split mode to be horizontal or vertical (depending on your screen size and resolution, you may prefer one over the other).
