CEM Problem with creating an event base alert for datasets sending an email.
Article ID: 280722
Compliance Event Manager
Created an objectvio policy statement with an email being set against the datasets .
Thousands of emails were issued within mintues.
This is the condition created
Condition  = ENTITY=*"CON." || ENTITY=*"CONTEST." || ENTITY!="C
             ON.DIRECT.DBA" && ENTITY!="CON.DIRECT.ADMIN" && EN
             TITY!="CON.DIRECT.OPER" && CLASS="DATASET"
z/os
The issue was because of no PARENDS
Change
Condition  = ENTITY=*"CON." || ENTITY=*"CONTEST." || ENTITY!="CON.DIRECT.DBA" && ENTITY!="CON.DIRECT.ADMIN" && ENTITY!="CON.DIRECT.OPER" && CLASS="DATASET"
To
Condition  = ENTITY=*"CON." || ENTITY=*"CONTEST."  && ( ENTITY!="CON.DIRECT.DBA" && ENTITY!="CON.DIRECT.ADMIN" && ENTITY!="CON.DIRECT.OPER" ) && CLASS="DATASET"
