Filters do not work when partitions are involved.
Steps To Reproduce
1. Create a lookup query. The following query can be used:
select
@SELECT:tr.z_name:z_name@,
@SELECT:tr.CREATED_DATE:CREATED_DATE@,
@SELECT:tr.LAST_UPDATED_DATE:LAST_UPDATED_DATE@
from
odf_ca_test_server tr
where
(tr.z_enddate is null or tr.z_enddate>sysdate)
and @FILTER@
2. Create a partition.
3. Go to Classic Administration > Data Administration > Studio > Team > object and create custom lookup attribute on the created partition
4. On the Project > Team , configure the lookup filter and list view.
5. Login as a user assigned to the partition and configure the project Team list and filter view.
6. Attempt to filter for a value that returns results.
Expected Results: The filter should work.
Actual Results: The filter does not work and blanks out while the filter displays all results.
Any other custom lookup field being used will reset the view.
Workaround: Use the personal Configure, but as soon as General > Restore Default is used, the issue comes back.
All
This is reported as DE79931.
The issue is not able to be reproduced in 16.2.1
