'Load Data Warehouse' incremental jobs fail with the following error occasionally.
ORA-20100: ENCOUNTERED EXCEPTION WHILE INSERTING INTO DWH_FIN_PLAN_PERIOD_FACTS.SQLERRM : ORA-20100: ENCOUNTERED EXCEPTION WHILE INSERTING INTO DWH_INTERNAL_MD.SQLERRM : ORA-01452: cannot CREATE UNIQUE INDEX; duplicate keys foundORA-06512: at "DWH_FIN_PLAN_PER_FACTS_LOAD", line 270ORA-06512: at line 2
Custom jobs that work on Projects, Teams etc., running in parallel to the incremental 'Load Data Warehouse' job.
Set custom jobs that touch Cost Plans, Projects, Teams etc. to be incompatible with the 'Load Data Warehouse' job.
