Run the query to reset the SQL Curve to null, example for Actuals: update prteam set odf_nk_actuals_curve = null where prid = <5xxxxxx> ----replace with actual IDs affected commit
Run Time Slicing Sync job to completion (note - on some environments it may take a while after you reset for many records, test the timings on a lower environment first)
