Download Limitation problem - Web Isolation Cloud
Article ID: 278158
Web Isolation Cloud
WI is generating error while user is trying to download a file:
"The current security policy prohibits the requested action. The size of the uncompressed archive file you are trying to download is too large: 1XXX MB This exceeds the administrator-specified limit of 1000 MB"
By default the limit is 1000 MB.
In the download profile > advanced settings, there is an additional configuration: archive.extraction.maxSizeMB which controls the maximum allowed size of an uncompressed archive.
To change the limit, navigate to the relevant download profile under WI Web GUI -> Profiles -> Download profiles and click Pencil Icon (In the example below default download profile is in use):
Then scroll to the bottom and click "Edit" button under advanced Settings:
Search for "archive.extraction.maxSizeMB" and modify according to the business needs:
Then click update and Push settings to take effect.
