During the failover data engine not be able to make a connection
Article ID: 276062
Updated On: 11-14-2023
During the fail over data engine not be able to make a connection due to which database got disconnected and data engine went to red state. how to prevent and ensure the issue will not reoccurred.
UIM 20.CU8
 As a prevention and ensure  the issue will not reoccur,  we have recommended to enable Always on Availability Group associated check points  from SQL Server probe which will let them know the replicate state and accordingly alert  whether it is primary or secondary.
