CMN_SEC_GROUPS table is slow performing, there is a lot of calls to this table that are hitting the database and raising its CPU
STEPS TO REPRODUCE:
select sg.ID as group_id from cmn_sec_groups sg
left join cmn_sec_user_groups sug on sug.group_id = sg.id
where( sug.user_id = :1 OR sg.is_hidden = 1 ) AND sg.is_active = 1
Expected Results: the query to run smoonthly
Actual Results: The query is running slower than expected, consuming database resources
Release : 16.1.3
This is DE78019, fixed in 16.2.0
Workaround: Create an index on cmn_sec_groups.is_hidden field manually by DBA, using the custom naming convention
(Alternatively create an index on both cmn_sec_groups.is_hidden and cmn_sec_groups.is_active)
Remember to drop this index prior to an upgrade to a higher version
