Need help in setting delay time for Service Virtualization API V3
Article ID: 274044
Updated On: 09-22-2023
I need help in setting delay for each response using sidecar file. I referred to the document and created virtual service by adding sidecar file for response side.
thinkTimeSpec=2000
I have the following files in the zip file
BrandAPI-req.txt
BrandAPI-rsp.txt
BrandAPI-rsp-meta.properties.txt
Using V3 API , when I try to create the VS  ,  It fails creation.
Release : 10.7
The Meta properties filename should be  BrandAPI-rsp-meta.properties  not BrandAPI-rsp-meta.properties.txt
Once we made changes to the properties file type , it worked.
