The question is occasionally asked: Will SPE scan a zero byte file and, if so, what will the result be?
Release : 9.1
Yes SPE will scan a zero byte file if it is passed in via a scan request. However, when it detects that there is no content behind the preamble of the file it knows that there really isn't much to do and will return a "clean" verdict.
