Unable to connect Power BI With Clarity Odata
Article ID: 273431
Updated On: 09-12-2023
Clarity PPM SaaS
We are trying to connect the Power BI with the Clarity Odata connector. However, are unable to use that.
The user we are using has the following access:
Data Warehouse OData Service - Navigate
OData - Access
Along with that it is an Admin user account which has all other administrative privileges.
Release : 16.1.3
Users cannot access the data warehouse OData endpoints using their Clarity SaaS Portal login credentials or domain credentials in a federated SSO environment.
Create specific report users in Classic PPM:
      a) You can re-use existing product users provided they do not have the External Authentication option checked in the resource properties under Administration. If the option is checked, create new report              users.
     b)  Set up a password for these users in Classic PPM, so that they can use it for accessing the Data Warehouse OData Endpoints.
Note: Also please disable the option to "change the password on next login"
